- May 7, 2012
- Dorset, UK
Right, I've been trying to tune my 3570k overclock and have been getting a bit frustrated with differing advice on temps, voltages, and how to stress test.
I have been running a 4.2GHz overclock for a while and decided to try and tune it a bit yesterday. I was doing an offset overclock with
This results in a load voltage of 1.3V which seems excessive for 4.2GHz. Max temp running Prime 95 was 85C.
In trying to tune it, I lowered the VCore to -0.005V (resulting in 1.296V load) and tested 4.3, 4.4, and 4.5GHz. 4.3 and 4.4GHz passed 15 mins of Prime95 and 4.5GHz crashed to BSOD with 0x1A.
As this was a memory error, might it suggest that I should lower my RAM speed to 1333 (it's rated 1600) for higher overclocks? Obviously it is rated as being stable at 1600 for stock clocks, but how likely is it to become unstable at 1600 when running on a larger overclock?
I am now back at stock clocks and want to check how good my temps are, what voltages I should be aiming for, and what is the best way of stress testing before I go any further.
So stock speed with all defaults in the BIOS:
My cooler is a Thermalright True Spirit 120 which is supposed to be just slightly better than a Hyper 212 evo. I'm using Arctic Silver 5.
Are my stock temps a bit high or are they ok? If they're a bit high, should I try reseating my cooler?
With my cooler (or a 212 evo) what is the generally considered maximum overclock? Is 4.5GHz considered doable or just the lower 4GHz range? I know every chip is different but I'm trying to gauge if my temps are higher than general or ok, and thus if I should bother reseating the cooler.
What voltage should I be aiming for for 4.0 - 4.2GHz? What voltage should I be aiming for for about 4.5GHz?
With a 24/7 overclock for general usage (gaming etc.), what is the maximum safe considered temp whilst running Prime95?
Last question, what is the best and most time efficient way of stress testing an overclock? I was thinking of running OCCT Linpack to test max temps, and then prime 95 for 10 mins, whilst tuning. Then after I am happy with my settings, testing 8-10 hours of Prime95 to make sure it is stable. Is this the best method?
Thanks in advance for any assistance anyone is able to offer.
- 3570K
- ASRock Extreme 4
- Thermalright True Spirit 120
- 8GB Corsair Vengeance CML8GX3M2A1600C9B
- VCore: +0.005V
- Turbo: +0.004V
- LLC 3/5
- Idle Voltage: 1.032V
- Load Voltage: 1.160V
- Max Temp in OCCT Linpack: 70C
- Max Temp in Prime 95: 67C
