Hello all,
My subject is as the title says, overlocking an i5 2500k which has been used for 3 years on stock frequency. I've bought a new gpu gtx 970 msi 4g gaming one. Even tho most of the forums say my cpu on stock doesn't bottleneck my gpu, i wanted to OC it since i have been thinking about it for a while now. I have a zalman cnps11x cpu cooler which i changed the stock fan on it to zalman zm-df 12 and with a thermal paste ( thermaltake tg-4 applied just a little). I've done some stress tests on it with prime-95 for 20 minutes ( i know it is not enough to be sure about stability but it seems damn too long to me to wait for 8+ hours :< ) So i installed intel burn test which i applied on very high and maximum for 10 repetitions. The results are as following attachments,
The temperature outside was around 13 degrees celcius when i've applied the test. And i've done the oc exactly as this site says ( http://rog.asus.com/76652012/overcl...k-with-maximus-iv-gene-z-to-an-easy-4-4ghz/3/ ). I left DRAM timing on auto since i have no clue about it and forum says i can so. And i didn't update bios really. I've read on a forum a few days ago that it's not needed.
Another thing is, when i tried to oc it to 4.4 with 1.250 V and stresstest it with prime95, it crashed on 3th or 4th minute. Then got in to bios again and saw that my cpu V was 1.300 V for a weird reason. So i thought it crashed with 1.300 V on prime 95 and upped it to 1.320 V. Then ran the intel burn test and it passed from both very high and maximum tests with 10 reps. But as i said, im not sure if this voltage is high for 4.4 ghz boost and wanted to ask u guys aswell. ( Thanks to Victorion as he helped me with it on tom's but you know i wanna ask more ppl for more information. ) Why im not sure about this voltage being high for a 4.4 ghz boost is as i said i applied 1.250 V as the rog forum guide said then it failed on P95 and when i went in to bios to up the voltage a bit more i saw it was on 1.300 V already. I really don't know why so i thought it ran and failed P95 with 1.3 V and upped to 1.320 V. This voltage and those temperatures are ok for this OC? Or are they too high and should i drop down the voltage a bit more? It seems stable so far (for 2 days ) on games etc.
Another question will my cpu last long with this oc and temperatures and should i keep my cpu cooler fan speed on 1600 and frequency on 4.4 ghz all times? ( It has got a button on it which u click and it boosts to 1200rpm and 1600rpm so it's running on 1600 all time as i set it to 1600 rpm. Or shall i activate speed step and auto fan control from bios ? ( Again Victorion named dude on Tom's told me i should. I wanted to ask u too. ) How would u find this cpu cooler compared to CM hyper 212 EVO? EVO is better or they're kinda same?
What i do on pc is playing wow, bf4, warhammer end times etc. And using solidworks from time to time. That's all really.
My system specs:
CPU:Intel i5 2500k
Mobo:Asus maximus ıv gene-z
GPU:MSI GTX 970 4g gaming
Samsung EVO 256 gb SSD with 500gb Seagate HDD
Memory: Corsair Vengeance 1333 mhz 4gbx2
Case: Cooler Master HAF 912 Mid-tower
CPU Cooler : Zalman cnps11x performa ( Changed the stock fan on it to zalman zm-df12 )
Thermal paste: Thermaltake TG-4
Thanks for sharing your time ! Have a nice day !
My system specs:
CPU:Intel i5 2500k
