- May 7, 2008
- Phoenix, AZ
You can try a lower multiplier, though the gains you realize may not translate into much which is noticable. If you want a stable system tomorrow I wouldn't start messing with settings today.
If the vcore won't change despite your BIOS changes I would call GB tech support. If they can't get it working for you I'd get an advanced RMA. That's me, though...I won't settle for a board that doesn't work like it should.
A lot of people are having hard time OCing the newer e7200 most will max out at 3.2-3.6 to go higher you need 1.4v+ ouch!
A 1:1 ratio is always the fastest. For example: If i run my ram at 1:1 with my settings (in sig) the spped of my RAM will be 790MHz - underclocked by 10MHz - but if i change the divider to 5:6 - it will be 940MHZ - but in actual performance tests, the 1:1 always wins by a few marks. So, long and short, always try to keep it 1:1 - but if you can, lower the multiplier and increase the FSB, so it is still 1:1 but at a higher rating;
395 x 9.5 = 790MHz (mem) and 3752MHz CPU
OR
417 x 9 = 834MHz (mem) and 3753 CPU
Same CPU speed (there abouts) but higher memory speed.
