P6T Deluxe V2 Power Switch
GearShift3r
I've just finished assembling my rig, but have gotten into a bit of a jam. The P6T's have an onboard power switch which works for me, but my front panel power switch does not work. I've checked the pin orientations and even tried a switch from my other case, but still no beans.
Can anyone help?
Thanks.
Daddyjaxx
Ormond Beach, FL.
Try shorting the power switch pins with a screwdriver and see if it starts. Just touch both power switch pins with the tip of the driver. That's how you used to have to start a motherboard before the onboard switches.
If it does start, the pins are good and your orientation or wires are bad.
