- May 31, 2004
- Birmingham, UK
Just to clarify btw, i'm using Sandra 2004 SP1.
Polariz^ said:Ok my spec is in my sig:
Arithmetic Benchmarks:
Dhrystone ALU 17031 MIPS
Whetstone FPU/SSE2 6862/12066 MFLOPS
Multimedia Benchmarks:
Integer iSSE2 42897 it/s
Floating-Point iSSE2 59202 it/s
Not absolutely huge numbers; but it depends what you use it for. This machine just absolutely burns though 3dmax renders and saves me loads of time (Roughly takes half the time of a 3.0C / 1000FSB), plus the warm feeling of having a dually
Hope this helps mate.
Go to my public profile for my detailed system specs. I haven't run any benchies yet and it'll be awhile before I do as I just don't see the need right now. This rig flat out screams through FAH WUs and averages 3k ppw just by itself. I haven't run any other heavy loaded apps other than FAH. I plan to eventually do real time video editing, video file encoding, rendering 3D models, Photoshop, etc. I'm kinda waiting on the results of Nocona E-0 stepping reviews before I bite and go i86-64bit OS.krag said:Dualie noob here...thinking about getting a couple xeons. Could you fellas post some Sandra's of cpu mips & mem?
I have a modded IC7 coming but if that doesn't do the trick for me I might go dualie...it all depends on if the performance is attractive enough.
The 60mm to 80mm adapters cost $1.99 each at a local Micro Center Store or $1.49 plus shipping on line. The Cooler Master fans were $5 a piece. Here's a link to the 80mm fan mod.disk11 said:http://www.gamepc.com/labs/view_content.asp?id=p4hsf2ghz&page=4
Heatsink w/o shroud. Results on page 8, and they really like it.
http://support.intel.com/support/processors/xeon/sb/CS-007773.htm
Shroud on the processor. If I remember correctly the stock fan does 8k rpm DaveB has modded this to take some 80mm fans, hopefully he could explain in more detail what he did.
Considering the shroud is like $10-15 bucks and you already have the heatsink from the Xeon retail package, its an almost no-brainer for me unless you want to use water/pelt/etc.
