- Apr 14, 2002
- missouri city, tx
since87 brought to lite on the formums here that running multiple pelts at way low power is a vary efficient way to cool something, becasue of the non linearitry of pelt out put vs. pumping power. what i was wandering is if yall had any ideas of how to actually measure the nonlinearity, so we can get some numbers for commonly used pelts in overclocking. it would require one to measure hom much heat the pelt is moving.
i had an idea of having a copnstand heat load, attached to cold side of pelts, with a heatsink attached also. then cool the hot side of pelt and blow air over the heatsinc.
assuming that *c/w is practiacl, adn thus if you double the heat load, the delta t will aslo double.
you ncould then:
run the set up with pelt V=o, so that all the heat load is passing through the heatinc, so you get a temp reading
runt eh pelt at 1v,then 2v, etc.
the graph of temp vs. trial should not be linear.
what do yall think, would this be an accrate way to do things. if so, i might do this, im very interested in some real world numbers on pelt efficiency.
you ncould then:
