- Aug 15, 2006
Hey folks,
I just picked up a Phenom II 965. After I installed it everything seemed to run nicely (I even set the multiplier to 18x with no trouble), but my system seems to be running really slow now. When I check System in control panel, it says AMD Processor Unknown Model @ 3.7GHz, but when I run OCCT it says my CPU is at 800 MHz (4x 200Mhz). I ran SuperPi 1M and that took 1.5 minutes, and my framerates on 3dmark06 dropped by half.
I manually set the HTT freq to 200Mhz, and the multi to 18. I haven't played around much with this motherboard, so I don't know the BIOS as well as I like, but my only other guess is the HT Link Frequency setting which I have on auto (not sure what that setting is, can anyone clarify how its different from the HTT?)
I'm stumped with whats going on here.
Motherboard: Gigabyte MA790GP DS4H
Everything else is the same as in my sig.
I've installed the AMD drivers for the processor with no luck. Running Windows XP SP3. I think I read some stuff about SP3 not working well with Phenom or something, but I cant recall where.
Any ideas? I really appreciate it
