- Jun 20, 2003
- Fontana, CA
HD3870X2 has two RV670 chips in case you haven't noticed.i alrdy have an idea.....ITS going to be better then the 3870x2....why would a new gpu come out thats going to be worse? and they alrdy have benchs i posted a link earlier
As I said, 2x RV670 has more pretty much everything that matters for GPU performance (ROPs and shaders) then RV770 - and the same amount of TMUs. So I can't possbily understand how you'd expect RV770 to be over twice as fast as a single RV670.
Something is REALLY confusing me...
There's the 4850, 4870 and 4870X2, they're all 512MB a core, they're all r600 based...
But how can they have GDDR3 on the 50 and GDDR5 on the 70's? GDDR3 would be too slow with a 256-bit interface and GDDR5 is very expensive, but ATi has slated the 4870's price to be $240...
jokers_greg,
512bit bus wouldn't make sense on a card targeted @ $200. GDDR3/4 is 3-5 bucks per chip and GDDR5 will be ever more expensive at first so the memory alone would cost almost ½ of the retail asking price. That means 512bit isn't going to happen.
And besides, memory bandwidth is something that allows the GPU to perform better. It's not something that will automatically increase performance. As can be seen from R600 - OC'ing the 512bit bus makes almost no difference at all. 512bit bus is makes no sense if you can use memory - like GDDR5 - that is fast enough to reach comparable bandwidths with just 256bit bus width.
i really hope ATI kicks some nvidia butt this time around. Any idea on cost for this new card?
I heard the price of the HD 4870 was to be $300+.
Basically it looks like the 4870 will use 4ghz GDDR5 clocked down to ~3.7ghz to save power. According to this, anyway: http://www.nordichardware.com/news,7728.html
Nvidia is sticking with GDDR3 for now, which would explain why they are thinking of a 512-bit bus, to make up for the slower memory. GDDR3 @ 1000mhz w/512-bit bus would have the same bandwidth as GDDR5 @ 2000mhz w/256-bit bus. Right?
Nope, GDDR3 and GDDR5 do not work on the same clock cycle, just as is the case with desktop DDR2 and DDR3. The GDDR5 on a 256-bit would be a bit faster then the GDDR3 on a 512-bit.
Technically, that makes no sense whatsoever.Nope, GDDR3 and GDDR5 do not work on the same clock cycle, just as is the case with desktop DDR2 and DDR3.
How so?The GDDR5 on a 256-bit would be a bit faster then the GDDR3 on a 512-bit.
Technically? So I guess you know everything there is to know about Ram, and all what can affect performance is bus width and speed? Your question is valid just don't be so accusatory.
Here's some info.
Read the damn article. It clearly states the bandwidth that GDDR5 has to offer in mass production for the first half of 2008. I'm fedup of posting links when nobody actually reads them, I hate spoon feeding, Google exists for a reason.
Calm down. I can't find anything on google that tells me what GDDR5 even means. DDR, simple enough, it transfers information on both the rise and fall of the voltage signal.GDDR2.. Does it do 2 transfers per rise/fall? Is is just a marketing name? Ditto with GDDR3/4/5? All the information I can find by googling is geared towards people who already understand the technology involved. I'm fedup of people who will post vague links and expect everyone to understand the information without 'spoonfeeding'... Or do you not understand the numbers yourself?
If you can't say something nice, .... This thread is probably on shaky ground as it is...
Once again: Can someone who actually understands the way memory bandwidth is calculated show how to figure out the theoretical bandwidth of (for example) 1000mhz GDDR3 on a 512-bit bus compared to 2000mhz GDDR5 on a 256-bit bus? Would GDDR4 at 1500mhz on a 384-bit bus be the same thing???
