- Dec 11, 2003
anyone?
Here's the deal on filters. A filter that's the same size as the fan can be very restrictive. I like my filter to have about 1.5 times more area than the fan or opening being filtered. I also like my filter to stand off at least 2" from the fan blades to eliminate the possibility of shear and turbulence. These 2 things ensure that fan restriction is very insignificant.
Jtanczos said:Meh. Sew together long sheets of filter material into something you can slip over your case. Cut holes in for your exhaust fans. Take the side panel of your case off and just have the filter material. Then ya dont have to worry. Im planning to line certain parts of the case with filter material. Hopefully it will help.
JT
OBLIVIONLORD said:Only issue I have now is to wait for one of you bumbs to tell me what type of filtering material I should use. GRR
bobad said:I have 2000 square feet of carpet and 2 cats I would like to give you.
bobad said:Oh man, you just gave me a dynamite idea. I'll just put my cats in a bag and my problems will be solved!
Koooler King said:The total number of fans blowing in or out won't make a difference on dust, just the overall net air flow ... think about it, the air flowing in must equal the air flowing out, or else your case would either explode or implode, right?
Strida said:No. The point of positive pressure is that all of the extra air is being forced out of all of the tiny air gaps in the case. Negative pressure results in air being drawn into all of these tiny holes, which when that happens, the air brings dust in the cracks. So if you have positive pressure, the only place dust is getting in, is the intake fans, as all of the extra air is being pushed out of the computer through the cracks/corners/etc..
