Hell... That's all electrical engineering students need. Source: See sig currently going into my senior year for a BAS in EE.... [emoji14]Most computer users are on Intel "U" laptops that are all dual core regardless of whether they are identified as i3, i5 or i7. Most Hyperthread out to 4 threads just like a standard i3. And that's all 90% of PC users need.
I could see needing something with more cores for VMs... But not for software... Dual boot if you need Linux for development. Works well on most laptops.
Also, my poor little i7-7500u handles Netflix just fine, as well as some light gaming (beyond earth, low settings, 1080p, very playable). It's not the slouch people make it out to be.
Not cad, but ltspice stuff I am. In fairness, my laptop was not happy with a probability and statistics project I did, but 36MB CSV files aren't liked in MATLAB regardless of hardware. MATLAB doesn't like large CSV files... Even the Ryzen wasn't happy with em [emoji14]Hah you must not be running simulations on your laptop.
EE at my school doesn't use CAD 3d rendering really. Mostly LTSpice and a smattering of programming languages to perform other simulations (RF modulation, etc). The 7500u handles transistor amplifier frequency response simulations and such just fine. Next semester should be interesting though. Software licenses are gonna force me to use the schools computing resources for one of my classes.
Have a cookie.
Mine was 4 gens old and also was trying to webgame as well. You can run *most* games on it with a fps penalty, some with none, and a few wont even play games with a two threads.
Aint noway AMD's Threadripper will come in under 1k. If it does, then intel better come out swinging.
That 12c part will be 800+... the 16c part 1000+...Really? The 8c/16t 1700 is just over 300 bucks, and Threadripper could be as simple as two of those glued together on a giant new socket. I'm predicting 800ish.
Really.
Personally I just wish Intel had kept the TDP much lower. That's the biggest let-down of the upcoming generations IMHO.
8 cores for 600bucks is not too bad.
It will overclock better than its Ryzen counterpart, with a 10% higher IPC per clock.
If the new platform mobos don't cost an arm and a leg (and a kidney!), that will be my choice for xMas rig (yeah, guilty pleasure...)
TDP doesn't mean real wattage. All processors are marked as 65, 95, 125, 140W,... but under full load some are showing higher or lower wattage. Intels were usually showing a bit lower wattage than TDP, AMD were usually showing higher wattage ( not a rule ). It's just hard to believe that +/-4 cores give the same wattage. When you check Intel offer then often i3 have the same TDP as i5 and i5 have the same TDP as i7. The same 6, 8 and 10 cores have sometimes the same TDP ( check Xeons ).
1700X under load is passing 110W while it's 95W TDP CPU. At 1.25V it's still passing 95W TDP ( hwinfo64 is showing up to 105W ) while it supposed to be Ryzen 1700 voltage which is 65W TDP CPU. So in real how far is real wattage from TDP on R7 1700 ?
I'm not expecting to see motherboards cheaper than X99 so they will be really expensive as usual.
I have no idea what about threadripper but if it won't overclock better than current ryzen then it's not interesting at all for me. Intel chips have 4.5GHz turbo so will make at least 4.5GHz on better cooling and all cores. This is what I need but 12c+ chips will be too expensive. I was counting on 12-16c ryzen while we got 8c max what's totally disappointing, especially they're almost not overclocking.
The only thing which is annoying in every single Intel X series chipsets are problems with memory slots and "missing" memory. Every single X58, X79 and X99 which I was using had problems with that and forums are flooded by issues regarding memory problems. I hope it won't happen on X299 boards but I guess if I decide to buy it then I will look for 4 slot board as with these are less problems and are overclocking better.
