L
lightning
Guest
when i run the prime on my P3 [email protected], the temp at that instance are about 25C. but after few min, the prime 95 told that "sumout error"?? i refer back to the README file and it said it's software problem!! this time i'm sure is not temp problem!! i just install the win2k and there was nothing inside there except prime95, sisoft sandra, MBM. and my pc setup was so simple, just include VP6 mobo, 1 chip P3750, Voodoo3 3000 AGP, one realtek NIC, creative DVD 6x, WD 5400rpm 8Gig HD. nothing more!! what happen is that?? oh...forgot another thing is now i'm running at 2.0V and i still can go higher to 2.05! >(
err...another question. i had observer that when the system is ideal, the Vcore are 2.03 - 2.04V from the MBM, but when i load prime95, it was just drop down to 2.01V!! is that normal?? did that give any clue on the problem i facing now?? :-(
