I have a abit kx7-333 board, 512MB samsung pc2700 333mhz ram, and a athlon 1600+ agoia. And I use thermaltake volcano 7 on the cpu. The problem is that once I overclock the cpu above 1650mhz, the cpu temp at full load (ie under prime95) becomes extremely high: 50c+ easily. And at 1743mhz, the cpu gets over 55c within few mins of prime95. After reading some of the cpu temps posted on this forum, I came away with the feeling that my cpu is extremely hot by comparison. One thing I suspect is that because my volcano7 has a variable speed fan controlled by temp readings from mobob, it might somehow get stuck at the lower fan speed of 2900rpm and never get the chance to work at 5000rpm. The cpu fan speed reading via Sandra seems to support this hypothesis. Unfortunately, thermaltake, being made in China, has the obligatory crappy packaging and wanting information: no manual, no instruction leafleft, no idea as to where on MOBO to insert the 2 fan plugs (one with 1 yellow wire, another one with one black wire and a red wire), and if there’s any way to bypass the variable fan setting by manually forcing the fan to rotate at max 5000rpm.
Your help would be much appreciated.
