PSU Mounting plate.
AudiMan
Winnipeg
I was wondering if anyone knows where I can get a mouting plate that would house two PSU's. For example. the full tower server cases come with a plate that has a hole for the PSU, and another few holes to mount a fan. This plate can be removed to add a redundant PSU, but I would like to replace this plate to allow me to use two power supplies.
tech2487
Illinois
not sure, but i wonder how you plan to use 2 psu's with the same system. if i were you i would contact the case manufacturer. thats how i got a clear side panel for my ever case.
Son1990
NPPL
Audi,
I have a template, given to me by Electron Chaser that will give you measurements and a design patter to cut out/make your own from Alum, Acrylic, or any other material you might want to use. PM me for it, if you still need it.
