Basically, if Windows do not crash during multiple CPU stress test (Prime95, OCCT, AIDA) does it means the voltage is OK?
I understand a too high voltage would result in overheating.
Too low voltage will cause BSOD, or POST, or Windows loading issue.
But, is there a state where the voltage is too low to supply enough power to the cpu, therefore, causing cpu to under-perform or causing performance issue. But without causing OS to crash ?
Is that kind of gray zone exist ? Or is it white or black ? Either it crash (have to ajust voltage) or not crash (= settings are fine).
Thanks !
Thanks !
