I've just overclocked my Intel i7 920 D0 (Full specs in sig) and I was wondering how do I go about the 24 hour stability test, which program should I use?
I'm currently using wPrime for a benchmark and to get CPU load to 100% etc
Idle Temps are : 33 / 37 / 36 / 32
Max Load Temps are : 56 / 52 / 55 / 52
(Click the image for a larger scale)
Also, if it passes the 24hr test, should I go higher? Whats the risk?
