With Gigabyte changing your BCLK, Bus Clock speed, from default they don't support the problems your haveing even though you move your multiplier down to 14 so that you don't overclock the CPU, they only support default CPU settings. The only exception is memory timing and speed rated for the board, even that is a gray area and they say we do not support the memory your using so they can get out of a RMA.
Asus definitely sound better at supporting all functions of bios and board when you seek help.
Here is just one example from Gigabyte support.
Sent : 3/8/2010 13:00
Question : My pc works fine overcloked however if you pull or turn off the power cord it hangs when you boot up, then you have to hold the power button for a minute to shut it off then it will start up fine. Can you make a bios fix to solve that problem.
Answer : Dear customer
If you do not make any overclocking adjustment do you encounter similar results?
We cannot guarantee any results off from overclocking
