http://img530.imageshack.us/img530/7041/powercasecordsje5.jpg
http://img530.imageshack.us/img530/6505/moboac2.jpg
Hi guys new to the forums, I would appreciate any help given and advice would be most welcome, first i will share my specs of my new build...
CPU: Intel Core Duo E6850 Conroe 3.0 Ghz
GPU: EVGA 8800 GTS 640 mb
250 seagate sata HD
2 gig crucial ram
as you can see on the pictures one of them is of the cables located in the Case, notice the "20+4 Pin connectors" called EVGA just to confirm if these 2 connectors are joined together then simultaneously inserted into the MOBO (which is the other picture), the EVGA rep said yes, these two connectors the 20 and 4 showed in the case picture with lines drawing them together both go connected into the MOBO, is this right? or do I just plug in the 20 pin connector? and leave the 4 pin conn. dangling?
My other question has to do with the MOBO CPU power Connector, Notice it is an 8 PIn connector on the mobo, but the PSU connectors in the case only produce a 4 PIN connector, i hear it is simple as buying a 4 to 8 pin converter, can I do this? or should I just plug in the 4 pin connector, I hope I didn't confuse some of you guys
but I'm not worried I'm sure you guys understand this stuff, I hope my inquiries will help other Modders as these questions are flying all over the internet, I tried searching still can't get some definitive answers, hope you guys can help me, oh and is 500 WT enough to run this bad boy, just wondering thanks
250 seagate sata HD
2 gig crucial ram
