Hello, I've asked this question in a few places and came to the conclusion my memory speed will be clocked down. I still need incite as I've never done much more than install a video card, sound card, or power supply. Here is my chipset dump:
I want to upgrade from 4GB PC3-8500 to 12GB (6x2GB) PC3-8500 or 10600 if my motherboard will support it. I noticed the CAS latency is higher on the cheaper RAM and if my motherboard bumps it down to PC3-8500 speed than the upgrade is somewhat useless as I could buy the RAM with the correct speed and lower CAS latency. Not only is the purpose of this upgrade to expand on memory, but to utilize triple-channel since X58 supports it.
Crucial 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500)
Kingston 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
Which set do you suggest I buy? I'll being buying two of either set.
Code:
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 529.1 MHz (2:8)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 59
Command Rate (CR) 2T
Uncore Frequency 2116.5 MHz
