- Sep 16, 2002
- Montreal, Canada
Hi guys,
Recently had some 775 goodness fall into my lap. 3 boards, and 2 CPUs.
CPUs: Q9550 and a Q6600 G0
Motherboards: Rampage Extreme (X48 DDR3), Maximus Formula (X38 DDR2), and a P5E Deluxe (X48 DDR2)
I'll be setting 2 of these up as full time folders, and I can't decide which board to run the Q6600 in. The Q9550 will be installed into the Rampage Extreme as I assume it's the best board of the 3.
I'm kind of leaning towards the P5E Deluxe for the Q6600 as it seems to have a beefier north bridge heatsink compared to the Maximus, which has a water cooled NB heatsink. I won't be water cooling anything, so I feel that the P5E may be better on air.
Maximus Formula:
P5E Deluxe:
Perhaps the Maximus might be better as it's a ROG board? I'm thinking I may be able to swap the motherboard heat sinks between the two as they seem to be basically identical boards, minus the chipset difference.
Both CPUs will be overclocked to their limits. Which board would you go with, and why?
Edit: Forgot to ask about CPU cooling. What I have available to me is an H50, and 2x coolermaster 212+ evos. I was thinking H50 on the Q9550, and a 212 on the Q6600. Would I be better off using the other 212 on the Q9550? I'm not very familiar with the H50. I do love my 3 H100s that I have running, though. I don't want to spend money on better heat sinks for these chips, I'll just use what I already have.
Thanks!
Maximus Formula:
P5E Deluxe:
Thanks!
