hmale is this the volkswagon antifreeze someone mentioned a few weeks ago? Also would this and the zerex super protector be good protection for a water cooling system? Thankshmale said:Hello guys,
Some of you have asked about finding the Silkolene Pro CCA product I mentioned previously. I do not have a direct link to the product, but if you go to www.silkolenestore.com and click on "maintain" on the menu to the left of the home page you will be directed to pages of different products. Just click next until you find Pro CCA additives (about 4 or 5 clicks to get there).
I like the product because it enables the user to maintain a higher water to additive ratio than required with Water Wetter or Purple Ice. A 1% solution is what is recommended. Another great feature is that it is odorless. For the aesthetically minded...it colors the water blue!
The downside is that it is rather expensive...
Hope this helps!
Prestone® Cooling System Treatment: Easy Pour-In Protection
Even though today's engines are more complex than ever, there are still ways drivers can improve performance of their cars and trucks. In fact, some of the most important vehicle maintenance is as easy as pouring in the right fluid at the right time. Now, there's an additive that can help extend the life of your cooling system: Prestone® Cooling System Treatment.
Not only does this product protect aluminum radiators and cooling system metals, it also contains patented grafted polymer water pump additives. Developed for use in all types of coolants, Prestone Cooling System Treatment helps new coolant provide vital water pump lubrication while it refreshes the corrosion inhibition capabilities of older coolants.
While it's still important to flush and fill the cooling system regularly, not even the most thorough maintenance can provide this level of protection. Prestone Cooling System Treatment can be added conveniently to either new or used coolant and can be used with conventional or extended life antifreeze/coolants.
