Hi and thanks for having me here
Didn't know if I should put this up here with the big boys
Planning my first Intel platform as an upgrade and was wondering if what I've read in a couple places was correct.
That since my H20 920 fits 1150 then it will also fit 1151 (Sabertooth Mark 1)?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835209054
The case is modded. 120mm rad fits nicley and airflow is determined.
So I want to stay with 120mm as long as I can get around 4.0 Ghz on 6600k. And I think that's doable.
Even if the 920 does fit, it's going on 4 yrs old so perhaps I should get a new one?, like Corsair H80i GT ?
http://www.newegg.com/Product/Produ...9&cm_re=corsair_cooler-_-35-181-089-_-Product
Thanks !
Thanks !
