Ok let me explain my situation first. I had watercooling about 1.5 years ago and loved it(in a socket A system). I plan on going back water with my new a64 rig but first I had a few ideas. I am currently doing the cisco program at my tech school(half day junior and senior year of high school) and the first year is general computers networking electronics, and I needed a topic for my end of the year report. So I am planning on watercooling my system taking a ton of pics and making that into my report(of coarse writing about watercooling). But,first I have a few questions since I have been out of the "loop"(no pun intended) for quite some time.
I have the folling parts from my previous watercooling system
Ehiem 1250 Pump
Custom welded heatercore(don't know what type of car it came from,my uncle fixes repo'd cars and sells them to dealers so he hooked me up with a few for my selection)
5/8" hose(A while ago everyone was going nuts over this hose from a plumbing supply place so I bought about 12')
Hydrex"Heavy Duty Coolent" made by swiftech
Some of those springy type things that you put around the hose so they don't kink.
T line and many assorted clamps ect.
Now the plan! and Questions I have!
I have a Danger Den maze4 GPU block that i used for my 9800 pro at the time. I was wondering if this will fit my Asus 7800gt (I would put ramsinks on)
Which CPU block do you recommend? ($50 MAX!!!)
I plan on making this an external setup. If ANYONE has any links pics how to's ect on external boxes that I could gather some idea's from I will have your babies
The plan is to go pump>rad>-TLINE-cpu>GPU(if possible>res>pump
I have a hollow Antec p-160(I think its been 3 years ill look on newegg for it)
That housed my internal setup using this pump and rad and it was quite cramped to say the least.
I plan on having 1 input line going through the case and 1 output line going through the case to keep it simple.
If anyone can suggest what i need to order,buy,make please tell me or any tips,I will be reading up on the forums for idea's and facts as I always do when I make something computer wise
Here is a ghetto pic of what I had in mind. Tell me if you think anything is wrong
http://img382.imageshack.us/img382/6567/wcpics2su.jpg
^Btw my craftsmanship is A LOT BETTER THAN MY PAINT SKILLS!
Ehiem 1250 Pump
