- Jun 7, 2011
Can someone tell me the exact size of a Seasonic X-Serie, 850W..
I try to fit it inside a Lian Li PC60 case (without removing any parts).
They say its 180 too. That guy is using a Adata 550W which is probably same size. Now i dont know which edge is 160 from that Adata, it seems like upward and not toward the back.
They say max length 180 mm, but something seems to be wrong at that description because when i measure the size of the bay it looks like there is 160x160 mm but not more than that (at the 2 highest attributes). Upward it could probably go as far as 170 however.
