BowerR64 said:We use cable and we have 4 IPs assigned to the cable modem but we are only using 1 threw the router.
Can i program each port to use a different IP? can you do that with a router?
NiTrO bOiE said:Hmmmm, put the router in bridge mode and then either dl PPPoE software (raspppoe) or use the built in XP client on each of the computers then use your log in name. Each computer will get their own WAN IP.
XWRed1 said:I've dealt with a Netopia "router" before, it was a big pain in the neck. So much I wish I could have replaced it with a real computer altogether, but I couldn't because it was also the dsl modem at this place.
My recommendation would be to either use a switch, or deploy a Linux or BSD box to use the 4 ips and firewall your lan.
The reason for having a router is so that multiple machines can share 1 IP. If you have 4 IPs and 4 machines, you don't need a router. Most ISPs only give one IP. Therefore, to connect my 5 machines to the internet, I NEED the router.BowerR64 said:We use cable and we have 4 IPs assigned to the cable modem but we are only using 1 threw the router.
