A few days ago I made a post talking about a recent cooler upgrade I made because my PC was getting too loud and too hot, which apparently was causing thermal Throttling. So I upgraded my cooler and made a thread about the results, where another user suggested my temps were... weird.
After looking online, I get the feeling that he might be right since most tests on this CPU easily put it well over 50ºC. Before the upgrade, it idled at about 55ºC and reached 72ºC while under load (the CPU temp is on the 4th graph on column to the right). BTW, it never went above that, which is why I assumed that thermal throttling was happening.
After the upgrade, I'm getting an idle temp of about 35ºC, with a room temp of about 23ºC. Under load with the blend test on Prime95, I'm getting a stable 49ºC. Also, its not just the readings, overall after the upgrade my games are way smoother and even the case feels cooler.
So, what do you guys thihnk? I'm thinking about doing some overclocking, which is why I would like to know if the temps are wrong.
