- Aug 24, 2003
- Netherlands
removing them fan grills will improve airflow by 33% to 50 % to maybe 60% depends on the restriction per grill...
if your ambient temps are higher than your room temps, then youll see a decrease in ambient temps, thus see a decrease in CPU temps!
good luck, and make sure you remove it all, unless you using tin snips, i used tin snips (sp?) i covered the back with a plastic bag, so debree would fall into the bag ( i believe archilochus uses the same method but i thought of this one myself too!)
