- Aug 19, 2004
- Florida
youngbuck said:That is currently a big debate in and of itself. Looser timing and higher clock speed, or tighter timings and lower clock speed? It seems to me that so far it is platform specific, but there are trends to be observed and recognized that throw wildcards in the mix.
GuitsBoy said:So lets say someone buys two 1GB sticks, he would be better off using them as 2GB in single channel as opposed to 1GB in dual channel? Atleast in the real world?
No reason to have redundancy in your RAM, dual channel is all about performance.GuitsBoy said:I though dual channel was akin to raid 1. Sounds like its actually closer to raid 0.
GuitsBoy said:Really? I though in order to run dual channel, two 1GB sticks sum out to just 1 GB. QUOTE]
This is wrong. 2 gigs is 2 gigs and 1 gig is 1 gig, no matter what configuration you have the memory sticks installed. You don't lose capacity by installing them in dual channel, hence, if your hardware has dual channel capability, there isn't much reason not to take advantage of it.
This isn't meant to be disrespectful or anything, but I have seen the misinformation about losing capacity in dual channel before. There is a very good sticky explaining about memory controllers being the key to dual channel and how on some motherboards, it is possible to run dual channel with three sticks if they are installed correctly.
Prot said:I understand. I did quickly read through many of the stickies, as well as the dual channel page on wikipedia, however when you've already got the misconception in your mind, you read what you want to. Anyway, thanks for straightening me out.GuitsBoy said:This isn't meant to be disrespectful or anything, but I have seen the misinformation about losing capacity in dual channel before. There is a very good sticky explaining about memory controllers being the key to dual channel and how on some motherboards, it is possible to run dual channel with three sticks if they are installed correctly.
Prot said:There is a very good sticky explaining about memory controllers being the key to dual channel and how on some motherboards, it is possible to run dual channel with three sticks if they are installed correctly.
Single vs. dual channel does not affect CMD latency not any other timings, the difference is in the width of the accessable memory. SC offers less bandwidth only because the memctrl is limited to access one 64bit wide "rank" at a time, thus halving the available bandwidth compared to dual channel allowing a simultaneous dual-rank (2x 64bit) access. "Rank" is a group of memory chips effectively operating as a RAID 0 array; the most popular (cheapest) practice is to group 8 individual 8bit wide chips together. The whole rank is accessed at the same time when memory is read/written, meaning 8 chips are always read/written at the same time.AlabamaCajun said:Running two sticks of 512 in single channel will be slower than 2x512 in DC due to slower command timing and hight lats needed to access 2 chips on the same channel.
I get less difference than that in my mem tests on my SN45Gv2 going from single to dual channel. Usually along the lines of less than 200mb/s.brakezone said:socket A benifits from duel channel by a very small amount, like 300mb/s in sandra bandwidth tests.
Depending on the system though, if you have mismatched sticks, running larger volume of single channel may be better than running a lesser amount in dual channel.Airbornederekc said:dual channel is always the better way to go. there is a reason there are 2 channel and quad channel systems (on server boards they have quad). there is no reason to go single channel over dual channel. you get no performance gain, you are only goping to hurt your system. your taking away from the capabilities of that system and slowing it down.
