right now im running my athlon 2100+ at 140x12.5 an am idling @ 42/43 and max load at 48/49 and having a case temp of 39 deg!! I have 3 WD SE Hds in there + Geforce 4 which im not sure if it is genning alot of heat. I have the side of my case open to. I just thought my high temps kinda weird, neh? (specially with a slk-800 and a 50cfm fan) Im using AS3 and i applied a nice layer to. The heatsink had a smooth surface, but I had tested it on another older cpu to see fi the clip would crack the die (which it didnt) and it left an imprint of the core on the HS...think that could be causing this? Any advice would help, ty
