Has anyone attempted to solder the IHS back on? I have a reflow plate & oven. I was hoping to not break new ground.
Google is failing because most hits just come back with discussions on delidding. I also can't find anything on the manufacturing temperature limits of the CPU while off, everything comes back with the Tjunction max limit
The closest I was able to find this Intel document:
SMT Board Assembly Process Recommendations
Intel® Manufacturing Enabling Guide
March 2016
https://www.intel.com/content/dam/w...rd-assembly-process-recommendations-guide.pdf
Which covers the suggested temperature profiles for board assembly. I can only assume that socketed CPUs have similar temp limits as the ones soldered to the board.
The plan was to delid, get everything cleaned up then apply a no clean solder paste (183C/361F Melting Point) to the die. Then reflow it, likely on the plate, with the CPU upside down.
March 2016
