Eclectic said:Steam sucks man, really it does! POS launching with windows....
Mathersalan said:I wish it did come with Quake 4..I bought Quake 4 back in my Linux days on my old build in Dec 06 and somereason the Quake 4 cd 1 fails during english pack or w/e tried it on different CD rom drives..tried MagicISO everything. I still have the cdkey yall think when Steams allows Quake 4 DL and I could use the orginal CD key?
But not generally for non-valve games. I have Call of Duty and I can't input it so I can get it in steamTyranos said:I used my old Half Life cd key and Steam accepted it just fine.
vixro said:As of right now, you can't use your current key to activate the game over steam and then download it.
What I had to do because I experienced this same issue was to actually download the pirated DVD ISO and then use my CD key that I bought with the installation because my CD based installation was crap too. Something wrong with Disc1 when they distributed it.
Qbix said:They are allowed to do that. Our license allows that.
You've never had to pay for Steam.Eclectic said:Do you still have to pay for it aswell? If its just a buddy list your after, why not use xfire? Asd for VOIP. Ventrilo FTW
vixro said:If I could directly buy stock in steam and not the company, I would.
hUMANbEATbOX said:I <3 Steam.. Can't wait for the new update.
And about them using DosBox, see this quote:
However it seems that they removed COPYING and other files which aren't meant to be removed.
I didn't put the whole post because the second part of it was refuted by someone else further on down the thread, and I didn't want to have to post that as well.SteveLord said:Next time you should quote the entire post. Seems to be undetermined if they can do this or not without at least crediting DOSBOX. But still....that is messed up, especially since the authors had no word of this at all.
MiniMax said:3. You may copy and distribute the Program (or a work based on it, under Section 2) in object code or executable form under the terms of Sections 1 and 2 above provided that you also do one of the following:
a) Accompany it with the complete corresponding machine-readable source code, which must be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
b) Accompany it with a written offer, valid for at least three years, to give any third party, for a charge no more than your cost of physically performing source distribution, a complete machine-readable copy of the corresponding source code, to be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
c) Accompany it with the information you received as to the offer to distribute corresponding source code. (This alternative is allowed only for noncommercial distribution and only if you received the program in object code or executable form with such an offer, in accord with Subsection b above.)
The source code for a work means the preferred form of the work for making modifications to it. For an executable work, complete source code means all the source code for all modules it contains, plus any associated interface definition files, plus the scripts used to control compilation and installation of the executable. However, as a special exception, the source code distributed need not include anything that is normally distributed (in either source or binary form) with the major components (compiler, kernel, and so on) of the operating system on which the executable runs, unless that component itself accompanies the executable.
Why does it stink? Valve/Id are selling licenses for their games, not the actual DOSBox. If anything it legitimizes DOSBox, it isn't just for pirates/people with a shoebox full of old games, and it is providing a vehicle to sell these old games to us all over again. If they didn't want people using their code in this fashion, they would not have designed their TOS this way.SteveLord said:Yeah I dunno...even if they can get away with it, that still kinda stinks.
