- Jan 12, 2012
Your best bet, if you're doing a complete build. Start a thread, let everyone know what the intended purposes for the rig are and your budget. There are a ton of people here that will get you the best bang for your buck. The majority of us have run, tested, overclocked and worked on numerous setups and will definitely help you out. You will most likely save money also because most people just want the biggest baddest, when in most cases the biggest baddest is total overkill. An example is you could look up compatible motherboards for the Fx 9590 and see the Asus Crosshair V Formula/Z that I have is on the list and say ok that's the motherboard I should get because it's one of the best. The reality is the Sabertooth is as good as the Crosshair V it just doesn't have all the bells and whistles the CHV has. Which are intended for Sub Ambient benching/Overclocking and are totally unnecessary unless doing so.
