- Nov 6, 2003
- Rochester, Michigan
Just got my new system today and altho i had to do a format of c without being able to back anything up im am now up and runnig. But here is the weird part. My system is very cold.
Heres my setup
Barton 2500+ week 24
SLK-900a with tornado 92mm fan (199cfm?)
Abit NF7-s rev 2.0
GForce FX
80 gig HDD
CD-RW
NIC card
400watt PWS
4 80mm system fans. 1 blowing in on the lower front, 1 blowing in and the side, 2 blowing out in the back top.
MBM5 says im at a chilly 14c with a system temp of 30c. Should the cpu be that low? Im useing a silver thermal paste. Not sure of the brand as i picked it up at a local store. 10% silver tho. is this ok? When i check the temps in PChealth in the bios it says the same temps. 13-14c cpu adn 29-30 system. If this is all legit then im very happy. But I dont want to be mislead.
Also im useing 512mb pc2100 memory right now at 2.5-3-3-6 I think. I can check again. I havent tried to messing with the FSB nore the multi at all. Is it possible to get any more speed out of my 2500 with this memory? Still waiting for the 3200 memory to arrive. But i wouldnt mind getting a few extra mhz in the mean time.
Also is there anyother temp monitoring programs out there that are easy to use? MBM5 confuses me.
Thanks for all your help.
Heres my setup
Abit NF7-s rev 2.0
GForce FX
80 gig HDD
CD-RW
NIC card
400watt PWS
