T vs Y fittings
coolroyboy2
Arundel, Maine
I am getting ready to install a second csp 750 and I was unable to find any Y fittings at the plumbing or hardware store. I have a couple T's , will using the T hurt my flow enough to make a difference in temps.
Also I plan on adding a chipset and GPU maze 4 on there own loop unless there is a better way.
I would say order some Y fittings, a T fitting will kill your flow beyond beleif.
Search and find the Y's dont use the T
