- Jan 9, 2005
Nah, get that instead...I can direct you to a thread that will fix the card and make it net 700kh/s+
I don't want to flash a different bios on the card, if that is your fix..
Yeah, that and undervolting makes a huge difference.
How do you guys cool side-by-side graphics cards?
I've tried different orientation/ordering of my 2x290X and 1x7950 and can't get one of them to not overheat. I had them in ports 1_34 so 1 could breathe and only the 3 and 4 were competing for air with a 120mm fan blowing in by the front of the cards (on my benching station) but they were still hitting 95C with the fans at full blast. I could try changing the TIM but that seems like it wouldn't make that significant of a difference compared to the overall issue.
So right now I just have 1_3_ with the 2x290X cards.
- This means you aren't mining which is bad. It is the result of your computer not having enough system ram. pretty weird huh? Basically get more system ram, or lower the thread concurrency setting. (Linux systems do not have this issue, and this fix only works on some systems)
try, in my experience many 533s will run 667
