Off to a nice start Pierre
Looks like an awesome place to take pictures!
Two questions:
-Are you shooting RAW?
-Do you have Photoshop?
I'm curious as to why those would be the first two questions you'd ask a newcomer who has stated they are just starting out. Neither is actually necessary. As a matter of fact, I spent the weekend with an old friend on a couple of shoots who doesn't use either, and takes some pretty amazing photos.
Two questions:
Yes, RAW format. I would assume not since you don't use Photoshop.
Since you don't use Photoshop I would let the camera control white balance if you aren't already.
Where would i go about setting that on Nikon D3100?
EDIT: Found, and is set to Auto
Kudos to you, by the way. I know people who've had their camera for years and never done that.
Auto should be fine most of the time, but it all really depends on the light. If you want to play with the other settings, choosing the "correct" setting is pretty simple... Look UP! If all you see is clouds, set it to cloudy. If you see blue sky, use daylight. If you see nothing but leaves, use shade, etc. That's the general rule, but don't be afraid to experiment.
Kudos to you, by the way. Your first day out and you've taken your camera out of auto mode (you didn't post your settings, but I cheated). I know people who've had their camera for years and never done that.
I really wish i could have captured this in higher detail.
If you have any questions, feel free to ask. I'm also available through gchat if you don't want to post it here.I have only been in shutter mode, i still dont know what the 3 others do for me. But i guess i must try it out. I run jpeg highest res. Its downsized for the forum.
Downsizing = resizing? I'm not sure I understand the question. I use Lightroom to resize photos, but anything will work. GIMP is a free option that would give you access to a lot more than resizing.What are you guys using for downsizing and does it ruin the quality other than lessening the size?
I sure notice that with the right photos. Facebook's insane compression makes it so I have to actually delete photos on occasion after posting them, because they look so horrid. Even already-resized-to-smaller photos, because of that DPI change.+1
I used GIMP for a while, and it can do a lot of what lightroom or photoshop can do. Resizing smaller generally doesn't do much to lessen quality unless you start messing with dpi. Facebook drops dpi down to 96 (from 240 or 320 usually, in my case) when it resizes your photos, and most people don't even notice. Prints are where you'll really be able to see it.
