- Jun 9, 2004
- Los Angeles, CA
yup, that thread was posted in the 'video and sound section.'
Godzilla said:Anyone know where i can find the soundtrack thats on Doom 3 on the main menu and at the end of the game when its completed?
Cheers.
Cheers.
secretweapon said:1) There is a stamina bar in your HUD. You use that up when you run, Doom doens't want you to run all the time. You only have unlimited stamine in hell levels.
2) The mods usuually comes with a readme file. Follow the instructions in there and you should be good.
cmcquistion said:I'm pretty sure you can extract it from one of the PK4 files in the base directory. They probably save audio files in there as OGG files or something. I'll poke around and edit this post, when I find out for certain.
*EDIT* I was right. Extract pak003.pk4. I contains tons of game sound. Do a search through those files for the largest of the files and you will probably find what you're looking for. They seem to have OGG and WAV files. There are two files in there that might be what you're looking for: music_credits.ogg or d3theme.ogg
I'm using foobar2000 to playback the OGG files.
Godzilla said:This may sound dumb but, how do i extract the pak003.pk4 file?
*EDIT* Nevermind, i used winrar
Can't seem to find music_credits.ogg or d3theme.ogg though
verbatim said:Just download it from **** or I'll send it to u in mp3 format.
cmcquistion said:They are in there. Extract the whole archive and then use Windows Search to search through the folder (and all its subfolders) for *.ogg
P.S. You can also use Izarc to extract files. It is freeware, instead of shareware, as Winzip and Winrar are.
