Great work man! Came out sick. Is this really your first build? If so, that's crazy. Myself for example have only ever done upgrades. Never bought every part, all new, all at once. At the best, I've done builds mostly new but reused a case.
I always get a little carried away with my hobbies and some things I'm just a perfectionist. as it sits I already have plans to make some changes to it. you might think I'm crazy but I think I can make it look even better.
had to every part because never had a desktop just laptops. also had to buy a lot of new tools to make this possible which I didn't mind cause you can never have to many of them.
got some parts for the water box. first is the fan controller which I cut some sheet metal to cover the top so I can mount the pump on top. next is the pump top, the res is from my main rig. going to use primochill hard acrylic tubing and fittings.
I was just going to say, when you put the fans onto the Rads, just becareful as you could put a hole in the Rad if the thread is too long!! But it seems you have already done this, i hope you did double check with a Flash light to see how far they went into the Rads!!
