Phextwin said:Excellent post!
What about metallic bonding?
It explains why metals conduct electricity and heat so well.
David said:Gases: structure and properties
Due to gases being more spread out, they are easier to compress. The pressure, volume and temperature of a gas are governed by the following relation****:
pV = nRT
Where p is pressure (in Pascals), V is volume (litres), n is the number of moles of gas (see above), R is a constant (~8.3) and T is temperature. Thus if volume is held constant (in a fixed vessel perhaps) and the temperature is increased, then so is the pressure.
David said:gonna try and get some thermal properties of various compounds in here
ShadowClock59 said:This is an awesome sticky, I also have an answer for why is water the best solution for cooling.....
My physics teacher told me once that if you dont know the answer to a question about water, one sure way to increase your chance of getting the right answer is to say that ITS POLAR!
So, not that I dont know at all why water is better, but I just wanted to say because its Polar.
David said:You are more or less correct . Water is polar => hydrogen bonding => stronger force holding molecules together => more energy reqd to heat water => higher heat capacity => better for cooling
Silver said:Can we get a mod in here to delete this guy.Seems his french is limited to one link in ALL the threads he has posted in.
That of course would be the above c3dlc .
