- Sep 17, 2005
Very scientific. this explains how each material and method affects the cooling. helpful when looking at specs
David said:Properties of Common Materials
Heat Capacities
Common Metals
Silver 419 W/m-k
Copper 385 W/m-k
Aluminum 210 W/m-k
Metals used for plating
Nickel 60.7 W/m-k
Chromium 69.1 W/m-k
dream caster said:This is wrong, heat capacity is the quantity of heat energy a material has to absorb to rise its temp one degree, it is one of the properties that make up a good liquid coolant (water has a big heat capacity); the property that you look for in metals is heat conductivity and that is the property you have the values listed up there.
dream caster said:This applies very much to pumps in water cooling; all the work the pump does moving water finally goes to heat it; so if you use an oversized pump you are only adding heat to system and rising its temp. If you use a small pump say 5W you add that heat production to your system, if you use a 50W pump you add 50W heat (just about what a really hot CPU produces).
David said:The nucleus is made up of two types of particle. These are the proton and the neutron. The proton is postively charged. In an atom there are always equal numbers of protons and electrons. Protons and Electrons have equal charge. Neutrons have almost the same mass as Protons but are not charged. These lead to various isotopes of elements.
The mass of an atom is expressed in terms of Atomic Mass Units (AMU) where 1 AMU ~= 1.66 x 10^(-27) kilograms. The mass of an element can also be expressed as grams per mole where one mole is equal to 6.02 x 10^(23) atoms. Thus 1g/mole implies that 1 atom has a mass of 1 AMU, 18g/mole implies 1 atom has a mass of 18 AMU etc.
BobcatDan said:The nucleus does not always have an equal number protons and neutrons in it (although you do talk about isotopes later). The main example is hydrogen, only has a proton in the nucleus. The isotopes used in fusion reactions, Deuterium and Tritium, have one and two neutrons respectively. Typically, however, for an element to be stable it will have an equal number of protons and neutrons. It is interesting to note that the mass of a neutron is greater than the mass of a proton by the mass of an electron, and that a neutron is in fact simply a proton and electron “stuck” together (this is all an oversimplification).
Feydd said:Now we need a Quantum Mechanics sticky from supernade.
Super Nade said:I would be most willing to oblige. Maybe an article on quantum computing?
Props to the seldom seen David
They actually use 6Li D (lithium-6 deuteride) to make H-bombs. Tritium will decay and have to be replenished plus it is harder to mass the two gasses together to be able to thermofuse them. the ⁶Li D (lithium-6 deuteride) is a stable solid cake and can be stored indefinitely.BobcatDan said:The isotopes used in fusion reactions, Deuterium and Tritium, have one and two neutrons respectively.
Fridge said:Nice thread... but what relevance does orbital arrangement have to PC cooling?
Audioaficionado said:They actually use 6Li D (lithium-6 deuteride) to make H-bombs. Tritium will decay and have to be replenished plus it is harder to mass the two gasses together to be able to thermofuse them. the ⁶Li D (lithium-6 deuteride) is a stable solid cake and can be stored indefinitely.
http://www.fas.org/nuke/intro/nuke/design.htm
http://en.wikipedia.org/wiki/Nuclear_weapon_design
David said:Water has a heat capacity of ~4200 J/K/kg meaning that 4,200 Joules (4.2kiloJoules) of energy is required to increase the temperature of 1kilogram (which is 1 litre) of water by 1 degree Kelvin.
