Is there even aluminum contact with that res/heatsink thing he is using? I thought the sinks/fins were on the outside only...?
its basically an alu finned tube section threaded into a steel cast base so it may take a long time but it will destroy itself.
the blocks are alu often with stainless barbs in them so there doomed to fail some day two. more likely to react on the blocks and leak on your expensive parts first.
the pump will fail from months to a couple of years... about three month if you place any more restriction in the loop. (its just a cheap aquarium pump)
on a note of restriction, the steel cast base is very restrictive bore and soon blocks with corrosive deposits. and the quick connect fittings also bring about restriction.
as for there coolant, ditch it and get some G11 and PT nuke in there. there formula fails to protect sufficiently. and breaks down into some lovely polymer strings... hmm slimey toxic liquid.
you need to clean the system out and replace the coolant mix every six months and give it an anual break down and inspection.
all the anti corrosives you can try will most likely partially work by coating everything with a protective layer which also serves to insulate the heat transfer the longer it runs without a full breakdown and clean.
ive got a resorator 1 v2 and resorator v2 - for thoes who havnt already had a good laugh
both of mine are showing signs of corrosion despite efforts to keep on top of things.
my mini review:-
way way way way over priced.
there rot boxes with no usefull long term parts.
seriously incapable of handling todays higher end CPU`s and GPU`s
did I mention there overpriced too?
Forgive them Lord for Zalman know not what they do.
anybody want a free one PM me, cover my post and packing and i`ll send it to you.
I was going to throw them in the skip as apposed to take them with me when I move anyhow there that good
EDIT: wait till conum see`s this, oh the controversy of days gone by... you were right Conum you swine
