Thanks QuietIce and Conumdrum, I checked with XSPC at the same time, Paul there, reckons I would notice a small difference, guessing thats going to be like the "6% gains with slow speed fans" from that link.
He also advised against using just one fan, so will be using the two Gentle Typhoons on the rad in a pull config running slow rpm, and then use an S-Flex for my exhaust.
Am guessing I can easily add a shroud later on. I'd rather buy a pre-made one rather than a home-made jobby, as I would want to be sure I get it right.
So far I can only see shrouds designed for specific double rads, or universal for single rads, would two singles next to each other be ok? Am guessing so.
Also been running some tests with the reserator with two sflexs zipstrapped together and then stood on their end blowing cold air at the tower. This lowered temps quite well, although OCCT linpack still came up with errors. I updated the BIOS on the motherboard and the errors went away, so thats that one solved.
Am now running comparison tests (30 mins only) with the sflexs and without. Will post results in a mo in case anyone is interested in how the reserator works with a bit of added airflow.
