I need a new heatsink and fan the dragon orb 1 is not cutting it for me.
I figure I will go crazy and get the AX-7 and a Delta fan. (I don't sleep with my computer.) or the Swiftech MCX462 Heatsink + Fan.
Of course I've got some questions about them
1) Will the swiftech fit on the dragon plus with little or no bending of capacitors or blocking dimms?
2) I've read the horror stories on this board about breaking the mobo while installing the ax-7 this is one reason why I'm considering the swiftech and I like the mounting posts better than the clips. Is this wise? The extra $30 I figure is for peace of mind.
3) I've read that you can't plug a delta fan into the mobo fan control or you'll burn it up. Is this true? This is another reason I was looking at the Swiftech cause it looks like the fan is powered by the ps but it still has a monitoring output so I can use the cpufan monitor on the mobo.
Sorry about the longwindedness but if I'm going to drop $70 or even 40 bucks on a heatsink I want to make sure it's the last one I ever buy.
Thanks,
Jeff
Thanks,
Jeff
