- Jul 1, 2006
- Canton, CT
Can you possibly test your temps with one 120mm fan/ two 90mm fans directly on top of the cooler? I want to see how much further you can push the temps down, I might be getting one.
enz660 said:Can you possibly test your temps with one 120mm fan/ two 90mm fans directly on top of the cooler? I want to see how much further you can push the temps down, I might be getting one.
TTP said:There's not enough room to mount any fan in crossfire configuration.
I swapped the heatsink to gpu side on my secondary card and they both show the same temp. Measured using an infrared temp meter.
enz660 said:take out one card just for this test then....pleeeease? for meeee? lol
enz660 said:thermalright = ownage
for air cooling at least. Nothing beats their perfromance, I think we can all say that they make the best heatsinks.
They work with capillary action, not gravity so they can often be positioned where they seen to defy gravity and still work.gvblake22 said:Do you notice any temperature difference between the two different mounting configurations? I only ask because heatpipes work with gravity, and it seems like having the heatpipes pointed upwards might work a little better than downward.
gvblake22 said:YES! Thank you for the pictures! That last one was exactly one I've been looking for. So this thing defintely takes up a full two extra slots in addition to the card's slot, eh?
Wait, wait...TTP said:if you opt to attach a fan, then yes, it will take up 2 slots if you setup in GPU-side configuration.
gvblake22 said:Wait, wait...
From that last picture you posted, it looks like the FANLESS cooler takes up two full slots in addition to the card. Is this observation correct? How many slots does the cooler without a fan occupy?
My previous configuration:
Arctic Cooling X2 on 2 Sapphire X1900XT 512mb in crossfire mode:
TIM: Arctic Silver Ceramique
idle: 56C
load (2h of Oblivion): 78C
Thermalright HR03 (passive without fans blowing on it)
TIM: Arctic Silver AS5
idle: 45C
load (2h of Oblivion): 67C
Thermalright HR03 (with 2 S-Flex 120mm fans blowing from side of case)
idle: 38C
load (2h of Oblivion): 58C
Pro: this heatsink rocks! Thermalright comes through again.
