Thermaltake DUO462-3 Super-orb
K
kieran_d
Ireland, Belfast
This is my current Heat sink and fan is this any good. (I want it to overclock my duron 750 AKCA, will this do the job)
CH5-5K12
Rated Speed 5500 RPM
Air Flow 11.4 CFM
Thanks.
Staz
Lafayette, La.
The general consensus is to stay away from the orbs but since you already have it...
what are your current temps like?
if they are good then go ahead and overclock and then watch your temps. If they get to high then just go back to the default speed, and buy a better cooler.
Tachyon
Senior Member
Arkansas
kieran_d (Apr 23, 2001 06:54 a.m.):
Is this CPU cooler any good:
Thanks[/q
The Super Orb is good for stock cooling and moderate overclocking for AMD CPU's under 1GHz.
Tachyon
Senior Member
Arkansas
Thanks[/q
K
kieran_d
Ireland, Belfast
No, my current CPU cooler is a 'Cooler Master CH5-5K12' and it has the following specs:
Air Flow 11.4 CFM
Is this any good for overclocking my Duron 750 AKCA
Tachyon
Senior Member
Arkansas
kieran_d (Apr 24, 2001 08:09 a.m.):
Air Flow 11.4 CFM
That airflow may keep you from getting a good overclock. What is the name of the fan on it?
