- Feb 18, 2002
EDIT: May 09, 2012.
It's over. Version 10 now continuously nags to be updated.
Avira AntiVir Personal 12.0.0.1125 is out. Unlike previous builds, this one does not appear to require multiple reboots if you don't install spyware.
Previously we established that this is a program with one of the best antivirus definitions out there and it's free.
Sadly, since version 10 SP2, they introduced multiple nags to make you install Toolbars and other unacceptable crapware. Since it appears we can no longer simply update the definitions for version 10 non SP2 without updating the program, I was on the verge of giving it up - but it appears the just released build gets rid of the update nags which required multiple reboots to get rid of.
So as long as it is installed correctly, and Comodo Firewall or similar software is used to block these two files from accessing the internet:
C:\Program Files\Avira\AntiVir Desktop\apnstub.exe
C:\Program Files\Avira\AntiVir Desktop\ipmgui.exe
We should be good continuing to use this antivirus software instead of the pay-for alternatives, most of which have a track record of worse definitions than Avira.
[There was no version 11.]
Disconnect Internet connection. Double click on Setup.exe to install the program.
UNCHECK everything when asked to install Avira Toolbars.
Allow the configuration wizard to keep the default extended threat categories. [Do not Select All.]
(UNCHECK: Application (APPL), Fraudulent Software, Games, Jokes, Programs that violate the private domain, and Unusual runtime compression.)
*ABORT any update process when it automatically pops up!* (If you haven't disconnected Internet connection as instructed above.)
Setup the program before connecting to the internet:
Subscription to new virus definitions for this program is renewed automatically through product updates. It is not renewed through virus definition updates. If product updates are disabled in order to prevent installation of a newer version of the program, download the latest key file from
http://dl2.avgate.net/down/windows/hbedv.key
and either copy it to
and restart or go to Help > License management > click on the blue hbedv.key link > browse to the new downloaded hbedv.key > Open.
Options:
C:\Program Files\Avira\AntiVir Desktop\avcenter.exe
System Scanner (on left) > Configuration (Right middle part of the window) > Yes > UNCHECK: Follow symbolic links (middle right) > System Scanner > Scan > Action for concerning files >
Set for Automatic, Primary action: Ignore if wanting to just scan folders and get a scan report without deleting files or being prompted what to do if virii/malware is found.
> Update > Product Update > Do not download product updates. [This option is only for Avira Antivir product updates (Antivirus definitions will still be downloaded automatically.) Product updates should be downloaded manually by going to Update > Start product update... because they may affect the Windows operating system. They should preferably be downloaded only *after* imaging the operating system partition so that if they cause problems you can reimage back to the state before product updates were installed.]
> General > Security >
Disable being notified every time USB drive has an AUTORUN.INF file:
UNCHECK: Block autostart function
> General > Alerts >
UNCHECK: Show notice if the virus definition file is out of date
then
To disable Notifier nag screen: Windows 2000/XP Control Panel > Administrative Tools [in Windows 7, click on System and Security first] > Local Security Policy > Right click on Software Restriction Policies > Create New Policies > Right click on Additional Rules > New Path Rule... > Browse... to the path of avnotify.exe default is
C:\Program Files\Avira\AntiVir Desktop\avnotify.exe
> Set the security level to Disallowed > OK
Also block these two files from accessing the internet, using Comodo Firewall or similar software:
For Windows XP Home you would need to boot into safe mode and log in as Administrator, then
go to
and right click on it >
Properties > Security > Advanced > Edit > Select options not to let it execute for all users.
To submit a suspected virus, go to
http://analysis.avira.com/samples/
to upload it.
Turn off notification pop-ups after Antivir updates itself:
Administration (lower left) > Scheduler > Right-click on Daily Update > Edit job > Next > Next > Next > under Display mode, select Invisible > Finish.
You can scan multiple drives inside program options: Local Protection > Scanner > CHECK drives you wish to scan. The premium version also offers the option to scan multiple folders here. The free version does not.
In case of error message:
The procedure entry point ?_Xbad@tr1@std@@YAX4error_type@regex_constants@12@@Z could not be located in the dynamic link library MSVCP90.dll
download and install Microsoft Visual C++ 2008 SP1 Redistributable Package
http://www.microsoft.com/downloads/...FamilyID=a5c84275-3b97-4ab7-a40d-3802b2af5fc2
Manual updates can be downloaded from:
http://dl.antivir.de/down/vdf/ivdf_fusebundle_nt_en.zip
Unzip the downloaded file and copy all the contents to
Using two Antivirus programs at the same time:
If there are two Antivirus programs installed, you should not have two Antivirus *Guard* programs active at the same time because this would slow the system down, Windows may even have problems booting with two Antivirus guard components being active. So if installing AntiVir on a system where there already is an Antivirus program installed, do not install AntiVir guard.
Also disable the guard component of one program if using another program to scan an entire disk drive.
Default log file location is
C:\ProgramData\Avira\AntiVir Desktop\LOGFILES
or
C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\LOGFILES
For older versions:
C:\Documents and Settings\All Users\Application Data\Avira\AntiVir PersonalEdition Classic\LOGFILES
C:\Program Files\Avira\AntiVir PersonalEdition Classic
or
C:\Program Files\Avira AntiVir Personal\
C:\WINDOWS\Application Data\Avira AntiVir Personal\LOGFILES
Previous, now obsolete posts:
EDIT 2011-10-17:
EDIT 1:
EDIT 2:
Old version 10.0.650 (without SP2) download page while it lasts:
http://www.avira.com/en/support-download-free-antivirus
EDIT 3 :
And for Windows XP, old version 10.0.567 since later versions may still have (allegedly fixed) memory leak issues affecting Windows XP but not Win Vista or Win 7:
EDIT 4 :
I'm still looking into alternatives but until then I am using this workaround as posted above:
1. Disconnect internet then install v650 [or v567 if WinXP].
2. Disable product updates.
3. Connect internet and Start Update for definitions (not product).
4. Wait for the first pop-up to appear asking to install SP2, click on 'Install Later' then go to registry and
HKEY_CURRENT_USER\Software\Avira\AntiVir Desktop\Reminder
Change the value of MsgID1055 in the right window pane to 3
That workaround should work until v10 end of life.
The only down side I see is if Avira launches yet another new popup prompt in the future.
This is how I have Avirta Antivir setup
Configuration > Update > Product Update > Do not download product updates. [This option is only for Avira Antivir product updates (Antivirus definitions will still be downloaded automatically.) Product updates should be downloaded manually by going to Update > Start product update... because they may affect the Windows operating system. They should preferably be downloaded only *after* imaging the operating system partition so that if they cause problems you can reimage back to the state before product updates were installed.]
I do this because of the Windows XP killer update, which Avira released after v10.0.0.567, rendered Windows XP unusable due to a memory leak bug. After the initial fix, I still detected some problems and then decided to give up and not update the product on Windows XP. It was OK to update virus definitions - just not the product update.
This morning Avira rolled out a Service Pack 2 for version 10 which wanted to install itself even though I had product updates disabled. I drive imaged the system so I let it go ahead just to see what's up. All of a sudden it wanted to install the ASK toolabar (!) Avira had previously detected ASK toolbar as malware and now it partnered with them (!) As most of us know installation of ANY toolabar is not OK.
It also wanted to install Uniblue's registry "optimizer" which it also previously detected as malware. It is certainly scareware, falsely making you think something is seriously wrong with your system and only by paying Uniblue will you get the fix.
If you refuse to install these, Avira umbrella remains closed until you accept the installation of ASK toolbar and make ASK your default search engine!!! As a matter of fact, the protection is actually still up - but you have no way of knowing because there is no way to reopen the umbrella w/o installing crapware. Therefore:
Do not install Service Pack 2 for Avira Antivir 10.
Options:
> General > Alerts >
then
go to
to upload it.
or
For older versions:
or
EDIT 2011-10-17:
Brand new popup:View attachment 100537
Set MsgID1054 and MsgID1057 values to 3 to get rid of it.
Or save this as a .reg file using Notepad:
REGEDIT4
[HKEY_CURRENT_USER\Software\Avira\AntiVir Desktop\Reminder]
"MsgID1054"=dword:00000003
"MsgID1057"=dword:00000003
EDIT 1:
Lots of posts of people who installed Avira on computers of hundreds of customers, their phones are ringing off the hook because they are getting the blame. Most saying they are uninstalling and looking for the alternative.
10.0.0.690 is the version with SP2. Anything prior to that is OK. So both 648 and 650 are OK. I would stick with 650 on Windows 7/Vista and 567 on Windows XP then disable product updates and close any and all pop-ups offering product updates. Definitions for those can be updated automatically for a long time I would think. Hopefully by the time 650 reaches End of Life, things will sort themselves out.
Otherwise, stepping down to that thing Microsoft has is probably the only freeware option. Although I would rather start looking for free after rebate deals on Trend Micro, Kaspersky or McAffee. But really: uninstalling 690 / installing 650 then immediately blocking product updates is the best option now imo.
EDIT 2:
EDIT 3 :
For those using WinXP and needing version 567...@ Old Apps.
Thank you for using OldApps. Your download will start automatically
If not please click here: Avira AntiVir Personal 10.0.567 (42.05 MB)
EDIT 4 :
