Astro
- Oct 4, 2012
Hello Overclockers,
Overview:
This morning my first home-built computer (now ~1.5 years old) failed to output any display to either of my monitors. I have had this problem in the past with the same computer, but always after the computer losses power (unplug for dusting, etc). I have successfully recovered in the past by following the troubleshooting steps listed on this website, however this time I have no such luck.
System Specs:
Monitor: Asus 24" VE248H (x2)
Case: AZZA Genesis 9000 Black
Motherboard: Asus Sabertooth Z77
CPU: Intel i7 3770k
CPU-Cooler: Corsair H100
RAM: Corsair Dominator Platinum 1866Mhz 8GB (x2)
GPU: EVGA Geforce GTX 660Ti 3GB
PSU: Corsair HX1050 Modular
Optical: Asus
Mouse: Corsair Vengeance
Keyboard: Razer Ananasi
Storage: Corsair Force GT 120GB SSD (I use this drive to boot)
Seagate Barracuda 1 TB HDD
Upon Powering On:
The fans, drives, RAM, CPU cooler, and motherboard all show signs of receiving power. None of the red POST State LEDs stay lit on the motherboard, however the DRAM_LED does light up for a split second right when I click the power button. The Standby Power LED lights up as normal. The four-pin speaker makes no sounds. The monitors remain blank and in standby mode.
What troubleshooting I have done:
I first swapped out the HDMI and VGA cables I use to connect my dual monitors to my Geforce 660Ti, hoping for the easy fix. No luck, with the same results as above. I tried using only one monitor, with all combinations of cables and monitors. No luck again, so I double checked that my cables and monitors were indeed functional, and they all are. I cleared the CMOS and flashed the latest version of BIOS available on ASUS's support website. Again, no luck. I have also gone through every step of many troubleshooting checklists posted online. The last, and only step I have skipped thus far is breadboarding, which I plan to do tomorrow.
Suspicions:
This reoccurring problem happens every time the computer loses all power (unplugged, PSU switched off). This leads me to believe that the problem is in the motherboard, either in my CMOS battery or in my BIOS settings, which of course I am unable to access now. I am still a newbie in the field, so I am hesitant to do any guess and check troubleshooting without a more experienced opinion in favor.
EDIT:
Here are some pictures of my setup at the end of tonight's troubleshooting:
Overview:
System Specs:
CPU: Intel i7 3770k
Optical: Asus
Upon Powering On:
Suspicions:
EDIT:
