Hey all!
Just bought a brand new rig:
-MSI Z68A-GD65 (G3)
-Intel 1155 i7 2600k (sandy bridge)
-Kingston HyperX Genesis 2x4g DDR3 @ 1866 (waiting on two more for 16g total)
-Noctua NH-C14 air/air cooler
-Corsair 500R (with 2 extra 120mm intake fans on top)
I kept these from my old rig for now:
-Antec 650w power supply
-Radeon HD 5870
I updated EVERY possible driver with Live Update5 from MSI before doing anything.
I searched far and wide for a "stable OC" for this CPU. I decided to OC the turbo function. These are the settings I used in the MSI BIOS:
-Internal PPL Overvoltage *auto -> enabled*
-EIST *left enabled*
-Intel Turbo Boost *left enabled*
-DRAM Frequency *changed to DDR3-1866MHz*
On the tutorial is says to enable the "Extreme Memory Profile(XMP), mine has three options, Disable / Profile 1 / Profile 2. I left it disabled.
-Spread Spectrum *left enabled*
-VDroop Control *auto -> Low VDroop*
-CPU Core Voltage *auto*
-DRAM Voltage *auto -> 1.637v* (Kingston rates it @ 1.64v)
***CPU Features***
-Hyper-threading *left enabled*
-Execute Disable Bit *left enabled*
-Intel Virtualization Tech *left enabled*
-Power Technology *left enabled*
-C1E Support *left disabled*
-Overspeed Protection *enabled -> disabled*
-Long Duration Power Limit *95 -> 200*
-Long Duration maintained *left at 1000*
-Short Duration Power Limit *118 -> 250*
-1 to 4 Core Ratio Limit *0 -> 45*
Saved and rebooted. No problems booting up, all is good up to now!
Opened up CPU-Z, HW Monitor and IntelBurn.
Started at standard for 10 times. OC goes to 4489.7 MHz @ 1.384V. Temps are per core: 62/73/75/69 and package of 77. IntelBurn tells me that the OC is safe.
Here's my problem, IF I go to a higher stress level, two of my cores hits 96.. (88/96/96/92 with 1.392 v) and I get a nice blue screen saying that one of my cores crashed.
At idle, the CPU runs at 1596.4Hz @ 0.968V. Temps are 22/28/27/26.
Here's the batch and info from my processor:
Model: A
Ext. Model: A
Stepping: 7
Revision: D2
Batch: 139C325
After my 2nd blue screen, I checked my thermal paste if I had good coverage. I added a little blob in case, but coverage was pretty good since all of the backing plate was covered already. I used the supplied paste from Noctua btw.
From the "knowledge" I can gather, my cores aren't supposed to hit those temps at that clock speed (x45) and voltage (less than 1.39V) and I'm not supposed to crash either, I see people getting 4.8 with no problems. I'm pretty lost as to what I'm doing wrong OR is the problem with the hardware? Bad processor? Also, I find it weird that I'm getting such a wide range of temps. The cooler? Bad BIOS settings maybe?
Thanks for reading!
-MSI Z68A-GD65 (G3)
-Radeon HD 5870
***CPU Features***
Model: A
Ext. Model: A
Stepping: 7
Revision: D2
Batch: 139C325
Thanks for reading!
