Well you never can tell what from the Windows world will work with Wine (Wine is how you get windows stuff to work in Linux, but not everything works perfectly). Some of your steam library may work on Linux and other titles will work through Wine while some may not work at all. I think I linked it in the thread but there is a database of games that work through Wine. Ive never tried Afterburner, or Hwinfo so I cant say much there. I use something called psensor that does realtime monitoring of the vital stats.Okay so i read it. I think that if i had to pick from your list, id go with Kubuntu. But i do have some questions. Can you install normal microsoft programs? Like i usually use HWinfo, MSi afterburner, steam, discord, uplay, origin, chrome and razer synapse. is there a way to use these programs on Kubuntu? Would i delete windows off of my ssd or just create another partition and install it on that?
I think Elementary is a Ubuntu based distro that is geared towards elementary aged kids. Its loaded with typing tutors and math games and stuff. You will still be able to install all the stuff from the Ubuntu repositories though. Ill check it out Elementary though, but I suspect I won't get to it for a whileHave you heard of Elementary OS? I have someone telling me its a good beginner OS to learn linux.
So just a quick update on my fathers pc. Everything i did ended up solving the issue. THe problem has not occurred since. So yay![/QUOTE ]
Good to hear!
[QUOTE ] On another had. I tried Elemantry OS and Ubuntu. Long story short, I am staying with windows for right now.
I'll give it a shot later. I packed all my computer stuff up and don't have access to it right now. I like Linux except for the lack of support. All I do is gaming and the games I play aren't supported for the most part.Before you stick completely with the darkside try zorin and Linux mint. Ubuntu ia ugly and needs lots of attention to get how you like. Zorin has a button that transforms it into Windows clone. Friends dont let friends.... Windows
Will do tomorrow. The computer is two or three years old. The Mobo and CPU is about a year old. It's still running the windows that upgraded from 8.1 to 10.I would run memtest86 for the standard four passes and then run CrystalDiskInfo on the hard drive. File corruption can be caused by bad memory modules or a failing hard drive that has run out of reallocation sectors. I would check the hardware out before reinstalling windows lest you go to all that trouble and soon wind up with the same problem. I would also run Malarebytes on the system.
How old is dad's computer?
+1I would run memtest86 for the standard four passes and then run CrystalDiskInfo on the hard drive. File corruption can be caused by bad memory modules or a failing hard drive that has run out of reallocation sectors. I would check the hardware out before reinstalling windows lest you go to all that trouble and soon wind up with the same problem. I would also run Malarebytes on the system.
Check the HDD for errors. Also check "scan for and attempt recovery of bad sectors". It takes a while, but I've solved a few problems that way.
