do you think that could help the core temp difference?
Its a major pain to install this zalman
Benching everything @ 4.9ghz right now, tried at 5ghz a few times with no luck, upped the voltages, will try again for 5 in a bit
Doc was your last run on Dice or LN2?
Yep, Maxi's Mars
I think I just need to go colder I went from 1.625v at 4.8ghz to 1.65ish at 4.9ghz, then gradually tried all the way up to 1.74v but still couldn't clock any higher, then didn't see any point in trying any more voltage.
Well a big selling point of this board is the way high vcore it's capable of so I guess I just need to grow a pair and use it
Corey,
on your unattached pics, see how all of the TIM is spilling over the side of the CPU? Too much TIM......
Personally I still think that you have too much on that first pic as well, but not so sure that its dramatic enough to make much of a difference.
FWIW.......
Errrr well....I think you are talking to the wrong person about a big set of balls. As you well know my overly big balls have resulted in quite a bit of casualties on the bench station
