- May 2, 2009
Hello
This is my first time using unraid and I am having a hell of a time. I formatted my flash drive properly and get to the tower login screen then I am having problems from there. I have an ethernet cable hooked up from the server to my Macbook. The server shows up in my network settings "using DHCP" gives me an IP address 169.254.213.173. I can ping the server and it gives me a response. This thread: http://lime-technology.com/forum/index.php?topic=1347.0 , seems to be the same issue, but I have done everything that it suggests ie changed my IP manually to 192.168.0.1 and changed this up on the network.cfg file, but still no response when I type the IP into the address bar. I didn't fill in anything for the Gateway because I don't think I have one because the server is hooked up only to my Macbook and not to my router.
What am I doing wrong here? I am getting very frustrated. Can someone help me?
Thanks
Mike
Thanks
Mike
